Username: Taderbutt Oregon
United states
Post Number: 1 Registered: Nov-05
Thursday, November 10, 2005 - 00:38 GMT Can a Marantz 4120 reciever handle a 4 ohm load from a set of paradigm 9se mkII's?? Is a better reciever needed one that could support a 4 ohm load better?
United states
Post Number: 2 Registered: Nov-05
Thursday, November 10, 2005 - 00:42 GMT Just got the Paradigms wondering if another reciever is needed? eventually am going to upgrade to a multi channel any sugestions??
Username: Jan_b_vigne Dallas,
TX
Post Number: 6531 Registered: May-04
Thursday, November 10, 2005 - 01:48 GMT What does your owner's manual suggest? Is there any information on the back of the receiver regarding impedance load?
United states
Post Number: 3 Registered: Nov-05
Thursday, November 10, 2005 - 04:26 GMT Dont have the manual bought it used any extra info would be nice ill look on the back thanks
Username: Chitown Post Number: 434 Registered: Apr-05
Thursday, November 10, 2005 - 04:41 GMT You can e-mail Marantz and see if they will send you a pdf version of this manual.
Username: Fps_dean Williamstown,
MA
Post Number: 117 Registered: Oct-05
Wednesday, November 16, 2005 - 19:42 GMT The PM7200 says use at least 8 ohms for a single speaker and 16 for two (i dont know if that means 2x8 in serial or what though). Check marantz.com they may even have manuals online.
