Cheap bass system
Username: Eddyg519
Post Number: 25
hey im thinking about trying to get a basic extreme bass system for my PC. Basically just 2.1.. two speakers and one huge woofer.
How would i go about doing this? i mean i can get a good price on a car audio subwoofer...build a box but now would i route it to the PC? also how would i power a system like this? I heard you can use computer power supplies to power these things... is that true?
Username: Edster922
Post Number: 2838
http://www.newegg.com/Product/Product.asp?Item=N82E16836121122
or if you wanna spend more:
http://www.amazon.com/gp/product/B00009W44B
http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASB1
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-634
or even more money:
http://www.hsustore.com/stf2.html
Username: Eddyg519
Post Number: 32
well close, im looking just for basically an amp that can power a sub that is powered by the wall. So i can take a power cable from the wall run it to the amp that puts out maybe 500wrms, then hookup like a 12" type R to it.
How would i do this?
Username: Edster922
Post Number: 2839
depends...budget?
Username: Eddyg519
Post Number: 33
well i dont want to pay too much, i only need a powered amp that puts out around 500wrms.. just enough to power a sub and 2 cheap speakers.
Username: Edster922
Post Number: 2842
very helpful information there...
Username: Eddyg519
Post Number: 34
sorry im not exactly looking for a brand yet, just wondering what kind of hardware i need for this sort of setup...
