Current Source & Voltage Source?????
rmberard
I'm trying to hook up my NHT's to my Cinema Grandl and I only have a single pair of Monster cable going to each front speaker. Is it really neccesary to wire to both the current & voltage source? If it is I would have to run another wire above the carpet.
Username: Jan_b_vigne
Dallas, TX
Post Number: 6512
Does NHT say to run to both?
rmberard
quote "Does NHT say to run to both?" (Thanks Jan)
I'm not really sure. I have the books and manuals on everything BUT the NHT's. There model VT2's though.
Dallas, TX
Post Number: 6518
I'm sure NHT can give a very detailed explanation of how the speaker works. Or, possibly pulling up a review on the internet might be of some help if no one here is familiar with the speaker.
rmberard
Thanks Jan.
Can't find a URL for NHT. Any suggestions?
rmberard
OK, I think I've got it now. There should be a jumper between the red current source and the red voltage source and the same for the black. And I only use the current source on the Cinema Grand.
