Hawk......just need some quick advise
duke
what do think of m5 for fronts and sb3 for rear or vice versa,for yamaha1400,a friend of mine told me about ascend(never heard about it)which is a very affordable yet very superb sounding.
Username: Hawk
Highlands Ranch, CO USA
Post Number: 507
duke:
Either should work fine--I think both are superb sounding speakers, and are a good match for the Yamaha 1400. I tend to prefer using the SB-3s only in a free standing situation (on speaker stands), where the M-5s can be used on bookshelves, inside an entertainment unit, etc., as you can tailor its frequency response to account for strong boundary reflections.
But also check out the L-5s, which are meant to hang directly on the walls--they also sound great. They are an M-5 in an all aluminum housing, so they are not nearly as bulky, but give off that wonderful sound as they have the exact same driver array as the M-5.
So each speaker is a great choice, and it really comes down to how you want to install them as to which is the best one for you.
duke
hawk,
thanks for the information hawk,i have read a great review about the ohm walsh micro tall and micros matching center speaker,what do you think about them? and ascend cbm170 for the rears.im in taiwan,so i cant audition them.
Username: Hawk
Post Number: 511
duke:
I have not heard Ohm speakers for 20 years, but I have no doubt Rick Barnes's review is on the mark. I distinclty remember being knocked out by the sound of the Ohm Walsh F 20 years ago. The Walsh driver is very unique as it is a small thin cylinder that vibrates to produce the sound in an omni-directional manner. Like Rick, I found the sound to be clean, detailed, and very fast. In many ways, it does sound like a Magnepan. For whatever reason, and I will not opine why, Ohm speakers have never had widespread acceptance or penetration into the market. I had not seen Ohm speakers for a long time and I simply assumed they were either out of business or they had no distribution in my area. I was very happy to see they had simply changed their business model.
In response to reading Rick's posting about the Ohms, I went to their website and was very impressed by the micros and micro talls. I believe, and this is merely my opinion, the Walsh driver concept is a sound alternative to the traditional cone driver. I hope Ohm's move to being an internet only sales model will be a successful strategy. Innovation is a good thing, IMO.
Ascend is a traditional small cube, using traditional cone drivers. I think they are a very good speaker, with a very consistent frequency response across the audio spectrum. Very low distortion and they image beautifully. Their sound is somewhat laid-back, so it is best mated with an amp that is somewhat forward sounding (Yamaha) and not laid back sounding (such as an H/K or Pioneer Elite). Normally, this might be a serious mis-match since the Walsh driver in the Ohms is a very forward sounding speaker and the Ascends are rather laid back, so putting both into the same system may well create some dissonance. Instead, if you want a speaker to go with the Ohms up front, look into a pair of Aperion Audio Intimus 522Ds. They run just a bit more than the Ascends ($360/pair) and are a much more forward sounding speaker which will better match the Ohm Micros up front. Their website is www.aperionaudio.com.
Good luck!
