New member Username: OverdozePost Number: 1 Registered: Oct-05 | If anyone has any info on this amp, tech specs or reviews, I'd be very grateful Thanks |
nout Unregistered guest | System Digital integrated amplifier <amplifier> Rated output (20Hz - 20kHz and both ch drive) 100W + 100W (8 Omega) 120W + 120W (6 Omega) Dynamic power 220W + 220W (2 Omega) 180W + 180W (4 Omega) 150W + 150W (6 Omega) Total height harmonic wave distortion factor (20Hz - 20kHz, 8 Omega loads) 0.008? Cross modulation distortion factor (SMPTE) 0.008? Output bandwidth (8 Omega loads and THD 0.03%) 10Hz - 50kHz Frequency characteristic 10Hz - 150kHz, +0 -3dB Input sensitivity / impedance Phono MC: 250 mu V/150 Omega Phono mm: 2.5mV/47k Omega High Level: 150mV/20k Omega Phono maximum permissible input (1kHz) MC: 20mV Mm: 200mV RIAA deviation (20Hz - 20kHz) ±0.3dB S/N ratio (A network) Phono MC: 72dB Phono mm: 83dB High Level: 105dB Tone control Bass: 100Hz and ±8dB Treble: 10kHz and ±8dB Digital sampling frequency 32kHz, 44.1kHz and 48kHz S/N ratio (EIAJ) 106dB Distortion factor (EIAJ) 0.0035? Dynamic range 96dB Digital input Same axis: 0.5vp-p/75 Omega Light: -15 - -25dBm Digital output Same axis: 0.5vp-p/75 Omega <synthesis> Power source 100V and 50/60Hz Electric power consumption 200W External size Width 454× height 151× depth 379mm Weight 16.8kg http://translate.google.com/translate?hl=en&sl=ja&u=http://www11.plala.or.jp/se_ ke5583/MARANTZ/amp/pm-75.html&prev=/search%3Fq%3Dmarantz%2Bpm%2B75%26start%3D10% 26hl%3Den%26lr%3D%26newwindow%3D1%26safe%3Doff%26sa%3DN |
New member Username: OverdozePost Number: 3 Registered: Oct-05 | Thanks for the response. |
