I have JM Labs Electra 906 Anniversary edition with the Beryllium tweeter. Does anyone have a suggestion for a decent receiver. Currently I have them on B&K Pre-amp and amp, but want to move that to a different system.
Depending on your budget the Audio Refinement gear is a good buy. It gives you most of the performance of YBA at considerably less cost. Audio Refinement is by YBA and next year will carry the YBA name.
The only receiver that I know of that would do your speakers justice is the Magnum Dynalab at 3k.
I looked at the Classe CAP 151 but this used unit was snatched away before I could get it. Also Naim, Arcam, Moon. Magnum is supposed to be great. Thanks for the YBA tip. will have a look.
last weekend I listened to Naim, Arcam, Moon and Magnum Dynalab. Only the Moon I-3 was a bit disappointing. I ended up buying the Dynalab receiver. Thanks for the advice.
