Need help wiring a Yamaha RXV757 and NS515Fs
GBM
Hey everybody,
I recently purchased a Yamaha RXV757, 2 NS515Fs for the fronts, 2 NSM515s for rears and a NSC515 for the centre. (Got the whole setup, incl. all cables for just under $1000CDN thanks to my boss :D )
Anyways, to the question... I wanted to (i think its called this) bi-amp the fronts(hook up A channels to bass posts and B channels to mid/high posts). Right now I have 2 15" lengths of 12gauge wire hooked up to the 2 speakers' bass posts, and 2 12" lengths of 16gauage wire hooked up to the 2 speakers' mid/high posts. Is it alright to run the 2 different gauges/lengths to the same speakers? Whats your guys' opinion on hooking this system up? Any tips are appreciated!
Links to the amp/speakers:
http://www.yamaha.ca/av/speakers/ns515f.asp
http://www.yamaha.ca/av/Receivers/RXV757B.jsp
Thanks in advance,
Nate
