Speaker not working.
Username: Bib_macintyre
Post Number: 23
I have a technics speaker that wont work. The casing doesnt come apart. How do I get this fixed.
I have switched speakers and the other one worked and the original speaker that didnt work still doesnt work. So its the speaker. By the way ita a 3way speaker. bib.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 184
Remove the bass driver via the front, and peek inside. I had a Technics years ago that was fused, and rreplaced that only.
Look for the x-over and any signs of overheat. These speakers can use replacement x-o's found at radio shack et al.
Yes, the replacement parts are not exotic, but, truthfully, the speakers may not be either.
