Unregistered guest | I have found an old Akai amplifier at a second hand shop, but it has no price tag on it. The model is AM-U11 and it comes with a receiver, model number AT-K11. I was hoping someone could suggest a reasonable offering price for it so i don't get ripped off. it has 3 input channels, aux, phono, tuner, and i couldn't find a wattage output reference number on it. Any help would be appreciated! thank you! |
Bronze Member Username: Lockaudio801Post Number: 93 Registered: Apr-04 | LunaCrist, After testing that unit and finding it to suit your preferences then I would suggest you offer to buy it for $20 dollars tops. Make sure everything works ok. |
mik Unregistered guest | hi! there's one am-u11: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3811764370&category=22509 but it seems really old, too old for a receiver, is yours like that? i just ask you because i intend to buy that one, just because it looks nice |
LunaCrist Unregistered guest | Yes that is exactly the one. I found out the inputs don't work but i'm having an electronics friend of mine looking at it. Hopefully it's just a couple of loose wires. Ya $20 bucks sounds right up my alley..thanks guys! |
LunaCrist Unregistered guest | Oh and that's actually the amp not the receiver FYI. |
mik Unregistered guest | have you tried it yet? how is the sound and what speakers do you use? before i misunderstood receiver with remote... |
Silver Member Username: Project6Post Number: 503 Registered: Dec-03 | prone to pops and hiss at its age...nice during its day. |
