4ohm speaker question.
Username: Joshuatree
I have 2 MBQuart 4ohm speakers hooked up to my Yamaha 730 and they sound great. Problem is there doesn't seem to be alot of choices for 4ohm speakers to compliment them. Is it possible to convert them to 8ohm's or does anyone know of any good 4ohm speakers that won't break the bank. tia
Username: Timn8ter
Seattle, WA USA
Post Number: 559
Compliment how?
Username: Eramsey
South carolina United States
Post Number: 335
Joshua: A speakers characteristic impedence has absolutely nothing to do with one speaker "complementing" another. I'm assuming when you use this term you mean that the speakers are similar in sound and tonal quality. To do this,"voice match" speakers. They must a) be exactly like one another-identical,or b) be very similar from the same manufacturer in the same linage or close with the same drivers.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 159
Quarts are pretty aggressive, another pair would overdrive the amp I think.Whats th $ and objective?
