Username: Yqueque London,
Ontario
Post Number: 1 Registered: Oct-05
Thursday, October 20, 2005 - 09:18 GMT Which is positive on these, the wires run side by side like a lamp cord and end in RCA plugs.
Username: Quinn Post Number: 62 Registered: Aug-05
Thursday, October 20, 2005 - 13:28 GMT One has a stripe to tell it apart easily. It does not matter which you use for + or - as long as you use the corresponding ends to the same pole on both amp and speaker.
Username: Jan_b_vigne Dallas,
TX
Post Number: 6245 Registered: May-04
Thursday, October 20, 2005 - 16:39 GMT To make it simple, run the stripe to the positive conenction in all locations.
Username: Johnoas Sydney,
NSW
Australia
Post Number: 5 Registered: Nov-05
Monday, November 07, 2005 - 01:23 GMT As Quinn said, it doesn't really matter, as long as you do the same at each end. If it was a black stripe in white, I'd probably go with negative trace (stripe), as black is typically negative or ground. However, it could be a black cable with a white stripe, my convention wouldn't really stand up, as the no-stripe cable is "more" black. I generally go for negative trace, but it's not based on any scientific reasoning. Any installers want to shed some light on any working standards?
