My Marvin Gaye DVD audio doesn't output anything to the subwoofer on one of my home theaters. I have a Onkyo 602 receiver and a Yamaha C750 DVD player. My Onkyo LR552 and Toshiba DVD audio player outputs to the subwoofer on this disc fine. I have about 10 DVD audio discs and this is the only one with that problem on this system. Wonder what the problem is? I can't figure out what would make that particular disc do that? Any ideas?
Thanks in advance...
Rantz
Although it may show the LFE channel is active on your display window doesn't necessarilly mean there will be LFE present in the output. I have several DVD-A's and SACD's, for example that show a center channel is present but on playing there is no output - or so little it is really not noticable. It depends on the master and/or mixing I guess.
