Onkyo CR-505
Griswold
I've just bought a set of Paradigm speakers and need a cd player and amplifier to go with them. I was looking at the Onkyo CR-505, which includes a cd player, amplifier and DAB radio for a bargain price(A£220)
The problem is that the amplifier is rated at just 25W per channel, and that's at 4ohms (speakers are 8).
I don't listen to music particularly loud, and was wondering whether that amp will be sufficient to drive the speakers. I don't have a large budget, so the cd with built in amp was favourable. Any advice?
Username: Artk
Albany, Oregon USA
Post Number: 2007
The Onkyo will not likely be adequate to get the best from your speakers. Which Paradigms do you have?
Griswold
I've got a pair of Titans.
Griswold
The problem was not so much "Will I be able to get the best from my speakers", as I know I will not with a budget of <£300. I was just wondering if the Onkyo will allow a decent volume without distorting and damaging the speakers.
If not, is there any better solution with a similar budget?
Thanks in advance.
Username: Jan_b_vigne
Dallas, TX
Post Number: 6237
If the Onkyo is being sold at a dealership, I would suggest taking your speakers to the store and asking for a demo before you make the purchase.
Griswold
Ok, thanks for your help.
