New member Username: GeniusburkeLondonEngland Post Number: 1 Registered: Oct-05 | Does anybody know any tunrtable repair shops in London preferably CAMDEN. DJSTORE who i broguht them from say to send them to aberdeen where theyre based but im unsure as they will prob get damaged further. If annybody knows a place in london i would be very grateful |
Gold Member Username: John_aLondonU.K. Post Number: 3791 Registered: Dec-03 | http://www.radiocraft.co.uk/directory/classicaudio.htm Find "London" in the page. |
Silver Member Username: Frank_abelaBerkshire UK Post Number: 957 Registered: Sep-04 | What's the turntable??? |
New member Username: GeniusburkeLondonEngland Post Number: 2 Registered: Oct-05 | Numark tt 200 |
Silver Member Username: Frank_abelaBerkshire UK Post Number: 964 Registered: Sep-04 | That's a current model. I should look for a Numark dealer in London, such as Scenario Records in Westminster (http://scenariorecords.com) Google will get you loads of DJ equipment retailers in London and they should be able to help. Regards, Frank. |
Unregistered guest | I have a problem with my Gemini gforce sa 600 it's not changing speed from 33 to 45,I dont think it's major and I dont want to send it away is there any where in central london i can take it. |
Unregistered guest | Hi, I am able to help you with turntable problems. Also with mixer, sound sytem(P.A.), or whatever, also in studio. London East. First describe problem in email, then you have short answer with solution, if possible. Otherwise equipment must be repaired. regards, art |
