SONY STR-1GES VISION TOUCH
Username: Wd9iko
BROOKIELD, WISCONSIN USA
I WANT TO HOOK UP MY PHONO TO MY COMPUTER.
I WOULD LIKE TO BE ABLE TO PLAY A RECORD ON MY PHONO THRU THE AMP TO MY COMPUTER TO A WAVE FILE. I HAVE
A PROGRAM CALLED CLEAN THAT "SHOULD" LET ME DO THAT.
I KNOW I HAVE TO GET THE SIGNAL FROM THE PHONO TO THE COMPUTER..HOW? THERE IS ONLY AN INPUT TO A PHONO ON THE BACK OF THE AMP. DO I BYPASS THE AMP AND GO DIRECTLY TO THE INPUT OF THE SOUND CARD?
VERY CONFUSED.....
PLEASE EXCUSE THE LARGE TYPE..I HAVE POOR EYESIGHT AND NEED TO TYPE IN LARGE LETTERS. I AM NOT "SHOUTING".....
ANY HELP WOULD BE APPRECIATED.
THANKS
WD9IKO
Username: Stu_pitt
NYC, NY
Post Number: 652
DAVID -
SINCE YOU HAVE TROUBLE SEEING, I'LL USE LARGE TYPE AS WELL.
I REALLY DON'T KNOW WHAT YOU'RE TRYING TO DO. ARE YOU TRYING TO RECORD LP'S ONTO CD? WHY WOULD YOU WANT TO SEND THE PHONO SIGNAL THROUGH YOUR RECEIVER AND INTO YOUR COMPUTER?
YOU MAY WANT TO LOOK AT THE PHONO SECTION OF THIS SITE AND POST THERE. I DON'T HAVE MUCH EXPERIENCE WITH THIS, BUT I'D BE WILLING TO BET THAT YOU WOULD GO FROM YOUR TURNTABLE DIRECTLY TO YOUR COMPUTER. I DON'T KNOW HOW YOU WOULD GO FROM YOUR RECIEVER TO YOUR COMPUTER UNLESS YOU ARE USING A PRE-AMP SIGNAL.
YOU MAY NEED TO USE A PHONO PRE-AMP BETWEEN THE TURNTABLE AND COMPUTER. IF THE PROGRAM WAS DESIGNED SO THAT YOU DON'T NEED ONE, THEN THIS WON'T BE NECESSARY.
Username: Wd9iko
STU,THANK YOU FOR YOUR RESPONSE. I WANT TO BE ABL TO PLAY MY RECORDS ON THE TURNTABLE AND LISTEN TOTHEM AND ALSO TO CONVERT SOME OF THE RECORDS TO A WAVE FILE SO I CAN PUT THE SELECTIONS ON A DVD OR CD TO PLAY. I HAVE ABOU 300 33 RPM LPS THAT ARE QUITE OLD AND WOULD LIKE TO SAVE SOME OF THEM TO CD OR DVD.
THERE WAS A PREAMP FURNISHED WITH THE "CLEAN" PROGRAM BUT I CAN NOT FIND IT!!! I THINK WHAT I NEED IS A SPLITTER RCA CABLE SO I COULD FEED THE
TURNTABLE AUDIO TO MY AMP AND ALSO TO MY COMPUTER.
IS THERE SUCH A THING? I USED THIS SOFTWARE PROGRAM ONLY ONCE WHEN I GOT IT AND IT WORKED VERY WELL ELIMINATING NOISE AND POPPING AND RUMBLE.
I HAVE ONE OTHER PROBLEM...SINCE I SIGNED UP WITH THIS FORUM
I HAVE BEEN SENT OVER ONE HUNDRED EMAILS....FROM ECOUSITCS. CAN YOU TELL ME HOW TO ELIMINATE THIS?
I WOULD LIKE TO KEEP THIS FORUM IT ANWSERS ALOT OF QUESTIONS I HAVE ABOUT VARIOUS EQUIPMNT. BUT I DONT NEED HUNDREDS OF EMAILS...
THANKS
DAVE PATTERSON
Username: Stu_pitt
NYC, NY
Post Number: 653
DAVID -
I SEE WHAT YOU ARE TRYING TO DO NOW. YOU WANT THE TURNTABLE TO BE CONNECTED TO THE COMPUTER AND RECEIVER SIMULTANEOUSLY. I DON'T KNOW WHAT TERMINATIONS YOU HAVE. I KNOW YOU SAID RCA'S ON THE PHONO AND RECEIVER, BUT WHAT ABOUT THE SOUND CARD ON THE COMPUTER? IS IT RCA OR A MICROPHONE INPUT? THEIR ARE SPLITTERS AVAILABLE FOR RCA'S. YOU WOULD BASICALLY RUN AN RCA CORD FROM THE PHONO TO A SPLITTER. FROM THE SPLITTER, YOU WOULD RUND ONE SET OF RCA CABLES TO THE RECEIVER, AND ANOTHER CABLE - WHATEVER THE TERMINATION MAY BE, INTO THE COMPUTER. PLACES LIKE RADIO SHACK, BEST BUY, AND CIRCUIT CITY SHOULD ALL HAVE THESE THINGS.
AS FAR AS YOU RECEIVING HUNDREDS OF E-MAILS - GO TO THE TOP OF THE PAGE AND CLICK ON EDIT PROFILE. AFTER YOU LOG IN, SCROLL DOWN TO THE E-MAIL NOTIFICATION, AND UNCHECK THE BOXES. AFTER THIS, HIT THE SAVE PROFILE CHANGES ICON.
