Just got a small "credit" from a local (not in the US) audio store shutting down business and the guy owns me some money, the only way I can get my money now is by taking one of these all of them are 3 way foloorstanders (not towers) and they are from display: Cerwin Vega 10" KLH 12" JBL 10" I'm looking for the better sound quality out of the 3 I know the Cerwins are a bit harsh, would you guys consider Cerwin Vegas as good sound quality speakers? Generalizing out of the 3 which would be better? Thanks
Model #s would really help as each of these manufacturers make several speakers with those general woofers, which I suspect is what you're talking about with the inch measurements?
Pink F, Have you listened to any of these speakers? Only you can make the judgement if you like the sound or not. You may even prefer the sound of KLJ, in the end, you are the one that will live with the choices. Listen to them by using the music or material you like, then choose.
Pink F, Have you listened to any of these speakers? Only you can make the judgement if you like the sound or not. You may even prefer the sound of KLH, in the end, you are the one that will live with the choices. Listen to them by using the music or material you like, then choose.
