3 way crossover help
Username: Aooo
Post Number: 91
Just got a pair of JBL TLX600 3way speakers used from a friend, the midrange is very soft compared to the woofer and tweeter.
I opened up the drivers and wire terminal and I found that the crossover has 2 coils 3 capacitors and 2 resistors.
I know the Capacitor and Coils are used for the High Pass Low Pass filters.
Are the resistors there for attenuation?
If I bypass the resistor that goes to the mid, will that provide me more power to the mid?
Another question please, the basic 3 way crossover design consists of 2 HP LP filters, Is there a band pass filter as well or is the unfiltered signal directed to the mid driver?
Thanks in advance for any help
Username: Jan_b_vigne
Dallas, TX
Post Number: 6114
The resistor is there for attentuation. Removing it will alter the relative level of all the drivers hooked to that resistor. There is usually no "band pass" in a typical three way Xo other than HP/LP.
You might want to experiment with speaker placement before you decide to disconnect Xo components. It is far more useful overall and is easier to correct if you don't like the results.
Username: Aooo
Post Number: 92
Thanks Jan
Besides altering the relative level of the driver, No worries about it changing the cross frequency?
Dallas, TX
Post Number: 6120
Resistors don't do that.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1444
Yes they do.
You will likely switch the cross-over point by doing that.
Dallas, TX
Post Number: 6146
Peter - You're going to have to educate me regarding the type of network that would have this degree of simplicity and then use the resistor as anything other than a fixed L-pad, one each, for the mid and high frequency drivers. Any network I can think of where a resistor might (slightly) affect the way the Xo operates would likely be more complex than the six elements listed above.
