Amp to power ht subwoofers
Username: Kwwinfla
Largo, FL United States
Can i use a GEMSOUND EXA3950 3000W Stereo Power Amplifier (Features: 1400W RMS @ 4 ohms bridged mono, 700W per channel RMS @ 4 ohms 350W per channel RMS at 8 ohms, Left-Right level controls, Ground lift, Inputs: 1/4" and Balanced XLR RCA, Outputs: Banana binding post, 1/4" & Speaker on, Protect LED, Peak LED, Fan cooled, Rack mountable, 115V/230V switchable) to power my 2 home theater 12" dayton 300 watt rated subwoofers. I'm using a sony str de895 6.1 receiver?
Username: Jan_b_vigne
Dallas, TX
Post Number: 6102
From what you've stated, I can see no reason why not.
Username: Kwwinfla
Does anyone have an opion on which is better.
PYRAMID PA1800X 1800W Power Amp DJ Amplifiers (900 Watts X 2 Into 8 Ohms (2 X 250 Watts Rms) · Bridgeable To 1800 Watts X 1 Into 8 Ohms · 1800 Watts X 2 Into 4 Ohms · Thd Better Than 0.05% · 4 Speaker Connectons Via Banana Plugs · Speakers A/B Selector · Dual Rca & Dual 1/4" Phone Inputs · Dual Led Level Meters · Separate Volume Control For Each Channel · Heavy Duty Fan Cooled Aluminum Heatsinks · Led Clipping Indicator · Led Protection Indicator · 110/220 Voltage Selector · Switched Ac Accessory Outlet · Rack Mountable W/Handles · Power On/Off Switch · Headphone Jack · For Use W/All Mixers, Pa Equipments, Home Audio)
or
Pyramid PA1000X- 1000 Watt Rack Mount Power Amplifier (· Professional Component Bridgeable Amplifier · 500 Watts x 2 into 8 Ohms (2 x 175 Watts RMS) · Bridgeable to 1000 Watts x 1 into 8 Ohms 1000 Watts x 2 into 4 Ohms · THD Better Than 0.05% · 4 Speaker Connections via Banana Plugs · Channel A B Select)
or
GEMSOUND EXA3950 3000W Stereo Power Amplifier3000 Watts Stereo Power AmplifierFeatures: 1400W RMS @ 4 ohms bridged mono, 700W per channel RMS @ 4 ohms 350W per channel RMS at 8 ohms, Left-Right level controls, Ground lift, Inputs: 1/4" and Balanced XLR RCA, Outputs: Banana binding post, 1/4" & Speaker on, Protect LED, Peak LED, Fan cooled, Rack mountable, 115V/230V switchable.
Thanks for your time.
