Unregistered guest | I have planned to buy RBH 61 SE as my main speakers (small room, 11.5X24X8). The speakers are 8ohm. I suspect I need a subw. RBH 12 SE seems a good choice, but I don't know its impedance (not listed). Alternate set up possibility: Infinity BETA 20 sp. with Infinity PS 10 sub. Can anyone kindly advise me? I'm in over my head. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5993 Registered: May-04 | Both of your choices are powered subs? If so, the impedance of the sub is not a concern as it will be driven by its own amplifier and not the main amp. |
Unregistered guest | Thanks for the info. I've never owned a subw. I am using a NAD C372 integrated amp (2x 150w). Reading articles in this forum, I'm tempted by the Hsu STF1. Would this fit well with RBH 61SE speakers? (use:almost exclusively classical and jazz) |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5994 Registered: May-04 | Probably. The Hsu subs have erceived very good reviews. Take a look at this unit also. It is manufactured by a forum member. Looking at the parts quality in this sub, I would have very high expectations for this unit. It is a sealed enclosure which should give excellent results when used with music and a very satisfying low end for use with video sources. Drop Tim a line and discuss what you are looking for. He is very helpful. https://www.ecoustics.com/cgi-bin/bbs/board-profile.pl?action=view_profile&prof ile=timn8ter-users |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5995 Registered: May-04 | Sorry. Forgot to link to the sub. http://www.us.alegriaaudio.com/Tom%20Subwoofer.htm |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 2459 Registered: Mar-05 | Harold, if your room is not a small one, it might be worth it to pay an extra $100 for the STF-2 especially if you do any HT on your system. |
