HD set up with VCR
Username: Wtf_over__over
Please end 3 weeks of frustation for me! I have an HDTV. HD Comcast Cable Box (Motorola). DVD Player. VCR. Yamaha Home Theater system that will not up-convert from composite to component. To maintain the HD, I've routed: wall cable to HD Cable Box (coaxial), HD Cable Box to Yamaha receiver (component video & audio), DVD to Yamaha receiver (component video & audio), Yamaha receiver to HDTV (component video only). This works so far. But to add the VCR, I've routed: Yamaha receiver out to VCR (composite), VCR out back to Yamaha receiver (composite). I get sound but no picture because I was told by a tech that the component and composite can't "talk" to each other. I then added: Yamaha "monitor out" to HDTV video 1 (composite video (yellow) only). Still no picture. I pulled every component cable out of the Yamaha receiver and still no picture. I've changed TV to Component 1 & Video 1 and I've changed Yamaha receiver to Cable TV and VCR. Nothing is working. Is it possible to make this set up work??? Other connections that don't seem to be an issue: wall cable through splitter to HDTV (coaxial) to allow Picture-in-Picture, Digital Optical lines from HD Cable Box and DVD to Yamaha receiver. Thanks for any help!
Username: Jan_b_vigne
Dallas, TX
Post Number: 5973
I would take the low resolution signal (composite) coming out of the cable box and send the composite out of the cable box to the VCR directly. Then route the VCR to the receiver. Unless you want to copy CD's or other anolog sources to the VCR, this should give you the signal you require.
Username: Thunder18
Post Number: 34
Or, just send the coax from the cable box to the VCR. Then you get sound a video on one cable to the VCR.
Dallas, TX
Post Number: 5989
Of course, that isn't the best hook up if you have premium channels that need to be decoded. I assume cable still does that.
Username: Thunder18
Post Number: 35
Cable coax out to VCR coax in. VCR coax out to TV coax in. VCR on channel 3 and the decoding is still done by the cable box.
Thank you all. The problem with the suggestions is that my cable box only has one full set of component outputs and then one composite (yellow) video output. No other audio outputs. I can run that video composite to VCR but not sound. If I want to record with the VCR, I guess I'll have to use coaxial. I may just give up on recording, as I have a built in DVR on the Cable box. I gave up on my stand alone TIVO because it is not HD capable and the cable boxes ALL have only one set of outputs.
Will I be able to record TV and playback the VCR if I run: Cable Box to VCR (coaxial), VCR out to Yamaha receiver (composite), Yamaha receiver to HDTV (composite video only)?
THANKS AGAIN!
...and the fact that coaxial on the 65" screen looks AWFUL!
Dallas, TX
Post Number: 5992
That hook up should allow recording and playback.
Thanks, that will have to do. Now to put that entertainment center back together....
Username: Kano
Post Number: 698
I'm not even sure if composite (yellow) is better or worse than the cable run itself.
Cable Box -> VCR -> TV is the best route so you never accidentally watch HD cable in SD.
Investing in a DVD recorder is the best advice of course.
Right.
Dallas, TX
Post Number: 6001
No HD-DVD recorders, yet. Buy now. Throw away later.
