JeffW Unregistered guest | Hi, I came across a Fidek power amp for sale, but have never herd of this make. All I know is that it is made in Hong Kong, and is rated at 300w/c. Can anybody give me morre info. on this brand? Thank you, Jeff |
Silver Member Username: NuckParkhill, Ontario Canada Post Number: 131 Registered: Dec-04 | I liked it so much, I bought the company! Enron Financial Advisor |
JeffW Unregistered guest | Is that a joke? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5968 Registered: May-04 | Obviously not. |
Bronze Member Username: EddietfmanHong Kong Post Number: 11 Registered: Sep-05 | Fidek is a Hong Kong based company for audio equipment with her own manufacturing plant in China. I thought the amp that you saw is a professional power amp, not intended for home audio. They dont make high-end product but not inferior goods either. The bottom line is that they dont have service center network overseas. You can go to their web site www.fidek.com.hk to learn them more. |
Silver Member Username: CheapskatePost Number: 426 Registered: Mar-04 | they are another brand selling noisy "DJ amps" without the established reputation of other makes. i've seen fidek amps in my last MCM catalogue, but there's no reputation to compare to. if you want to check chinese amps out, there's an ENTIRE website with "new york" in it's name that's nothing but chinese gear. without digging my MCM catalogue up, fidek gear has the same 90dB s/n ratio of other cheap "pro" gear with a prettier silver aluminum faceplate. |
JEFFW Unregistered guest | That was the honesty I was looking for. I guess $200 for a 300w/c usually is too good to be true. Thanks EDDIE and B.M. |
