Marantz SR4300 DTS Decoder
Hi,
I have a marantz SR4300. My DVD player(LG) has a DTS digital output. I recently tried playing a DTS surround DVD. But i do not get any audio only the video. It says on the DVD that the DVD player should have "DTS Digital Output " written on it(My DVD player has that)and a compatable DTS amp with decoder. And the SR4300 has the following logo "DTS Extended surround". How do I play the DVD.
If i change the audio settings on the DVD(not the DVD player but by selecting on the audio menu of the DVD itself) to PCM then i am able to get the audio.
Is it a issue with the DVD or is it that the amp cannot decode DTS format.
Thanks
Rogger
Check your settings on the player. Set the audio output to bitstream and in the films menu select 'set up' or the equivalent and select the dts option. The receiver should recognise the dts signal automatically. Other than this I don't know what else you could try.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 133
nice call aono.
Dude owes you $4.98
