Advice needed?
grease
Hello
I have currently got a decent enough seperates system, but don't have a CD player/transport at the moment...since the last Technics one died...
I have three options available -
1: Use my home PC. This would be a convenient soloution, wouldn't cost much, and I can have easy access to MP3's, and play CD's. Does the sound card matter when it comesto sound quality? Is it better or worse than a normal CD player?
2. The Sony XES system. I have one of these (the P1 I think, made in 1991) a complete system for In Car audio for a while now. This is a super high end system. Can this be used for home? If so what will I need?
3. The obvious, buy a CD player seperate!
Username: Edster922
Post Number: 2294
Marantz 4300, $142 shipped from accessories4less.com is a steal.
Your PC's drive and the Sony car player will not be anywhere in the same league, especially if you have good speakers and separates.
grease
Hello, thanks for you reply. The Sony car player is real super high end with digital cables, Burr Brown D/A's shouldn' t that sound better?
