i recently bought some new banana plugs off ebay (gls audio) but when i screw the wire into them i find that the wire comes out with just a little pull. is this normal, or should i fold the wire (it is 14 gauge), or just screw tighter? also are banana plugs usually used when connecting the speaker wire to the speakers or should i connect directly from the wire? thanks a bunch everyone
ok. should work considering there is no pulling of the wire if the speakers just sit there. Also i only use my setup in one room so would it be better to use bananas or connect directly to the speaker?
