Sony reciever plays only loud sounds
Dainius
Everything worked fine until I moved my speakers(5.1) and my reciever to another room. I connected everything the exact same way and now my front speakers play the loud sound the way they are supposed to be(well i think) and the quieter ones REALLY quiet. So I hear eather almost nothing or loud. But that doesn't happen with Radio, wich plays fine. At first I thought it was the cables but its not - i changed them. I tryed conneting and reconnecting and all sorts of thing but i got no idea what else i could do to fix this problem.
Anyone have any ideas?
Thanks upfront, Dainius.
Username: Jan_b_vigne
Dallas, TX
Post Number: 5797
It would appear you did not connect everything just as it was before. Assuming, of course, everything worked before you moved it.
What sources are not playing well? Have you gone back to re-read your owner's manuals?
Dainius
Well, I don't have the manual anymore and the sources that don't play well are the TV and CD player I changed the cables and its not the problem. Like I said the wierd thing is that with the Tuner(FM) everything works fine.
