Skylan stands?
justwondering22
I am buying a pair of skylan stands. My speakers are 8" wide, and I can get the top plate customized to any size. Do I get the actual width or do I go a little under, say 7", in case of future upgrades and the speakers are more narrow?
Thanks for any help
Username: Paul_ohstbucks
Post Number: 2468
If you're considering upgrading, you might want to sell those bookshelf speakers and buy something full size.
Username: Jan_b_vigne
Dallas, TX
Post Number: 5783
Actually, you would be all the wiser to totally ignore anything Paul posts. We all try to.
Get the top plate to fit what you have now. Worry about tomorrow when tomorrow comes. At least when it concerns hifi.
Username: Dmwiley
Post Number: 1104
Remember, when Jan has nothing of substance to say (which is about 90% of his entries), he likes to attack others. Sign of a petty mind.
Username: Edster922
Post Number: 2025
Actually the top plate of the speaker stands don't necessarily have to be of the exact same width as your speakers...as long as your speakers don't weight 100lbs and the stand is well constructed to be stable and strong, you could easily have an inch or two narrower top plate on each side of the top plate. Most people Blue-Tac (I know Jan doesn't like this method) their speakers to their stands which forms a pretty strong and safe bond anyways. As long as your kids don't play tackle football in your listening room you should be fine.
Post Number: 2472
Dale,
Well said.
Post Number: 2473
I'll bet eddie could use blutak to wallmount his speakers.
Username: Jimvm
Louisiana U.S.A.
Post Number: 213
Dale wrote: "Remember, when Jan has nothing of substance to say (which is about 90% of his entries), he likes to attack others. Sign of a petty mind."
Actually, if you were being honest, you would have to say that the overwhelming majority of Jan's posts contain a wealth of information of substance which is useful and helpful to many on this forum. I don't agree with Jan's position on many things, e.g., differences in amplifier sound, etc., and much of what he says is over my head, but as far as I can tell, he does not go out of his way to disparage other folks and the choices they've made in audio gear. Paul, on the other hand, does go out of his way to do so.
It is simply that Jan, like quite a few others on this forum have grown weary of the inane, smart-alec and unhelpful comments by your soulmate Paul. On the other hand (again, if your were being honest, which you're not) if you want to single out someone on this forum whose posts are 90% lacking in substance and 90% intending to insult other forum members, single out Paul. If you were honest.
Username: Edster922
Post Number: 2028
huge ditto goes to Jim, esp. where Paul is concerned.
Paul lately has been working very hard for the "resident moron" title.
Username: Dmwiley
Post Number: 1109
Yeah, Jimvm. A wealth of frequently irrelevant info. Paul shoots it straight. He doesn't try to hide his biases under technical language. Jan can give plenty of "white papers", but he can't answer a simple question. Choose your poison.
Dallas, TX
Post Number: 5786
A simple question: Has Wiley suddenly become the most insultingly worthless contributor to this forum?
A "White Paper" answer: Undoubtedly!
Wiley, what is it with you? Are you just following me around to make insulting comments? You have had nothing to say that has amounted to anything intelligent. You dislike others who can answer a question without resorting to insults. No wonder you find comradery with the likes of p.
Please, wiley, some of us are trying to conduct a conversation. If you have nothing to contribute, stay out of the way.
Username: Dmwiley
Post Number: 1113
"Are you just following me around to make insulting comments?" Could be.
Username: Jimvm
Louisiana U.S.A.
Post Number: 214
Dale wrote: "Yeah, Jimvm. A wealth of frequently irrelevant info. Paul shoots it straight. He doesn't try to hide his biases under technical language. Jan can give plenty of "white papers", but he can't answer a simple question. Choose your poison."
Quite frankly, I didn't expect an honest answer from you. What I expected from you was dishonesty and the continued sycophancy -- and you didn't disappoint me.
Ya know, I don't have a problem with someone who "shoots it straight" or someone who "doesn't try to hide his biases under technical language." What I do have a problem with, as do many others on this forum, is someone who intentionally, without provocation and with obvious malice, goes out of his way to sling insults toward others. One whose repeated use of derisive terms to describe not only the choices people make in their audio gear but the people themselves. One who does so repeatedly, even after people have asked him to give it a rest. There's no doubt that if Paul stopped his insulting remarks, others would stop responding with insulting remarks. But, if he chooses to continue, he can be sure that others will respond in kind. And you can go right on trying to defend the indefensible.
Dallas, TX
Post Number: 5787
ed - You have misread several of my comments. I am not pushing you to favor the NAD over the Panasonic. I am asking you to listen and understand why you find one more appealing than the other.
As to the BluTak and stands, I neither favor the use of BluTak nor do I argue against its usage. I argue for experimenting with the various options available until you are satisfied with the sound you achieve. My HT speakers are cemented to their stands with a VPI brick cemented to their top side. However, I found the Lings did not offer their best sound when I followed suit with them.
My argument is against following a practice merely because someone else told you it worked for them in their system. Experiment and listen; then choose for yourself which is best.
Username: Edster922
Post Number: 2036
fair enough, Jan. I stand corrected on both counts.
(Will post soon on the Panny thread as I have now come back to it after a couple days with the NAD exclusively.)
Post Number: 2476
The only thing being insulted is the HT audio when it's forced to play through tiny undersized speakers. You should consider yourself lucky you arent taken to court for fraud for impostering a come cinema.
Username: Edster922
Post Number: 2045
Hmm, I think the members of this forum should create chip into a pool to pay for Paul's therapy.
How 'bout it, y'all?
LOL
Dallas, TX
Post Number: 5798
That bill would dwarf what we'll spend on New Orleans and end up with far less of value. I say we just shoot him now.
Username: Edster922
Post Number: 2051
well maybe we can get Social Security or Medicare to pay for it...
Post Number: 2477
It only figures you socialists would congure up new ways to spend someone elses money.
Username: Edster922
Post Number: 2066
yes, we have to do it to get the mentally ill off our streets and Internet forums...
LOL!
justwondering22
So I am guessing I unfortunately tapped into something ugghhhh "bigger" here.
Maybe posting here is a bad idea. I guess Ill just go an listen to my "tiny undersized speakers"
LOL
phart buster
Petty minds full of gas and no substance. Attack others with whom you disagree. Pathetic.
Username: Edster922
Post Number: 2072
phart buster...an apt name! lol
