New member Username: TomteschPost Number: 1 Registered: Sep-05 | Hi.. I'd like to hook two center channel speakers to my center channel output on my reciever. To stay in 8ohms do I just run the positive to one speaker positive and the negative to the other speaker negative.. AND then run a wire from each speaker together (which offsets the reduction to 4 ohms if hooked up in Parallel). Thank you! Need help before I f* something up. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5733 Registered: May-04 | Try this arrangement: http://www.termpro.com/articles/spkrz.html A series connection will raise the impedance of the total load so this will not remain at 8 Ohms. |
Silver Member Username: Timn8terSeattle, WA USA Post Number: 528 Registered: Dec-03 | Wire them in series. Your amp will thank you. |
