Need some receiver help-have Marantz SR5400
PatrickBateman
I currently have a Marantz SR5400 and just picked up some Monitor Audio S2's at a great price. They sound great, but the Marantz has a much harder time pushing them that the previous speakers I had.
Any suggestions?
Should I sell in an pick up something like a NAD receiver for a few hundred more or should I just add something like an external amp?
Username: Devils_advocate
Post Number: 390
"They sound great, but the Marantz has a much harder time pushing them that the previous speakers I had. "
How are you gauging this? Is the Marantz getting hot? Is it not able to push it the new speakers to high volumes? Is there audible distortion?
PatrickBateman
Yes, the Marantz is much hotter and I have to turn the volume up much higher to reach the same volume level
Username: Artk
Albany, Oregon USA
Post Number: 1659
How high do you have to turn it up? What are the individual channels set at?
PatrickBateman
For example to reach 70db on the RS sound meter the volume previously had to be around -28 on the receiver. Now it has to get to -18 or -20 to reach the 70db range
Username: Artk
Albany, Oregon USA
Post Number: 1660
What are the channels set to?
Username: Artk
Albany, Oregon USA
Post Number: 1661
Must run, time to shower for work. I'll check this thread again at lunch.
PatrickBateman
Channels are set to small, crossed over at 80
Username: Artk
Albany, Oregon USA
Post Number: 1663
What are the individual volume settings on the channels? -1-2-3 0 +1+2+3 etc.
PatrickBateman
oh ok.
Left is callibrated at +1, left is 0
PatrickBateman
whoops
left is +1, right is 0
Username: Chitown
Post Number: 309
Patrick the Marantz pick up around -20 and then go really high from there. I doubt it is having any problem pushing small speakers.
Username: Edster922
Post Number: 1939
I second Stof.
I usually had my 5400's volume at about -15 when watching DVDs, definitely no lower than -25.
Username: Artk
Albany, Oregon USA
Post Number: 1665
Also can turn the individual channels up a bit as a gain.
PatrickBateman
I have them around -20 or -25 for music
with movies, it needs to be pushed to -10 to -8 to get the same leve.
And this only running 2.1
Username: Edster922
Post Number: 1955
that's normal Patrick, think nothing of it.
Username: Paul_ohstbucks
Post Number: 2420
I agree with edster. That model doesnt have very much power, so I would think nothing of it. You should expect to crank that knob a long ways to get any decent volume.
PatrickBateman
ok thanks guys
so if this model doesnt have much power, whats a good step
a new receiver, or add an amp?
Post Number: 2423
Patrick,
So long as you're getting enough volume, it shouldnt matter if the volume is at -8 instead of -20.
As long as it will produce enough volume for your taste, I wouldnt be concerned where the knob is on the dial providing it isnt waaay up in the +'s.
If the receiver isnt shutting itself off because of the heat, I wouldnt worry in the slightest.
https://www.ecoustics.com/electronics/forum/home-audio/160136.html
