Budget FM Tuner
Username: Banyanleaf
Post Number: 38
I listen to FM programs a lot and would like to get a decent used tuner (are there any new product offering of tuner seperate anymore?). There are tons of options out there and I am just confused. I see a local store that offers a Sansui Classique T-700 in good condition for sale for 30 bucks. Should I go for it? I did google this model but could find nothing. All I can find suggests that it is not from the GREAT SANSUI 70-80s product. Any advice?
Username: Jan_b_vigne
Dallas, TX
Post Number: 5716
My advice? A tuner is as good as its antenna and its location.
Username: Dmwiley
Post Number: 1101
Relatively speaking, Jan has a point. But there are tuners that have great selectivity and sensitivity. Luxman comes to mind. If you can find one of those at a fair price, grab it.
Username: Edster922
Post Number: 2123
or look for a used NAD tuner on eBay, should be really cheap, well under $100. What I like about mine is that it tells you where the signal is strongest, for instance an FM station that is officially 88.7 might actually sound better tuned at 88.85!
Unfortunately Houston's FM is mostly Clear Channel Communications garbage, I only listen to the NPR station and one very weak college alternative station.
Username: Dmwiley
Post Number: 1125
Edster, how are those NAD tuners in fringe areas?
Need to Register?
Forgot Password?
Enable HTML code in message
