Help! Does anyone know about Infinity Speakers?
ed v.
Just need feedback, Good for surround sound? Any feedback will be appreciated. thanks
Anoni
They are sold at CC
Username: Rsxman
Post Number: 38
They sound good, but that's like saying chocolate is better than vanilla...its pretty subjective
ed v.
Are they comparable to some of the stuff that's posted in here? Thanks.
Anoni
ed v.
Get real man. Infinity make speakers from $300.00 a pair to $5000.00
Be more specific, which model do you have in mind?
Username: Jan_b_vigne
Dallas, TX
Post Number: 5555
If he uses the $5,000 ones for surround, does he still need a center channel?
Username: Dmwiley
Post Number: 1035
In general and in my experience, Infinity speakers have a clean midrange, soft high frequencies and average bass punch (Paul would probably not like them when compared to his Cerwin Vegas). They tend to be a bit on the power hungry side. But you have to listen for yourself
Anoni
sure, if he decides to use 5 $5000.00 speakers for his whole surround system then why not ! :-)
Username: Paul_ohstbucks
Post Number: 2346
Dale,
I knew a guy who had a pair of massive Infinities back in the 1980s that would rock like you wouldnt belive. They were even bigger than the D-9s, and considerably more expensive. I've even tried to google them up(just for fun), but came up empty because I didnt know the model number.
Dallas, TX
Post Number: 5576
What if he wants 7.1? Does he get 7 $5,000 Infinity's and then \-2 {one little bitty tiny infinity?}
Dallas, TX
Post Number: 5577
I hate it when that stuff doesn't work.
anoni
hey man, it's all about the money! :-)
ed v.
No, I'm only considering the Primus voice matched 6.5 inch surround for my Onkyo tx-sr702. Thanks for your feedback.....
Username: Dmwiley
Post Number: 1044
Paul, I bet those "massive Infinities" required 1000 watts a piece just to whimper.
Post Number: 2361
Why would you say that?? You dont even know what speakers Im talking about. Heck, I dont even know what they were.......LOL
Username: Dmwiley
Post Number: 1062
Because traditionally Infinities are not very efficient. Maybe your mystery speakers were the exception.
Post Number: 2363
To the contrary, I've tried to google vintage Infinity speakers and found that many were in the 97db+ range.
I never did find the pair my friend had though. Im guessing they were built circa 1985-1989, but cant find them anywhere on the web. Some of their older models from the 70s-80s look pretty interesting. From what I can see, Infinity has evolved from being a leading edge manufacturer, to just another clone blending in with todays boring and plain designs.
Dallas, TX
Post Number: 5670
Infinity is no longer the Infinity of days past. Arnie Nudell, one of the three founders of Infinity, has moved on to design the Genesis line out of Colorado. I believe Infinity is still designed within the Harman Group.
Username: Dmwiley
Post Number: 1073
Hook 'em up and in many case you will find that Infinity overrated it's sensitivity. I've owned probably 4 pair over the years. All were power hungry.
mojo86
Thanks for your knowledge. They're rated at 88db
mojo86
