Speakers for NAD C370?
So, I decided to start my first HT system with this integrated amp, but I am not decided yet with wwhich speakers should I go. I am thinking to PSB 4T or 5T or to Ascend Acoustics CBM-170. What is your opinion?
Any comments higly appreciated
Username: Sun_king
Leeds, West Yorkshire UK
Hi there,
I've got a C370 amp running Kef Q5 floorstanders and I thoroughly recommend the end product - the Kefs blend perfectly with the Nad sound. I haven't tried either of your preferred choices so I'd recommend you audition them with some Nad amplification to see if you like what you hear. Ultimately which speakers you choose will be down to personal preference. You'll find that with the C370 amp you can drive ANY speakers so the world is your oyster!
Username: Lockaudio801
Post Number: 97
Can you give details on what was your preference integrated amp? Also how big is your room area?
Post Number: 98
ooops sorry,
The Kef Q's would go well with the NAD-C370. rightfully so an audition is in order while you are in the process try to hear the Triangle Stratos series if it's available.
