Using LG Receiver Speekers for TV. Need Help. Simple Fix should help
Username: Mow
I have an LG DVD recevier and I wanna know how to use the speakers (5.1) to play TV. I have connected all the inputs (red,yellow,white) from the system to the TV just dont know how to play TV sound through speakers. Can any one HELP! cheers
Username: Project6
Post Number: 3890
I see you already started your own thread. I apologize.
Now to answer your question.
If you want to hear the sound coming from your tv on your external speakers by using the receiver, you need to patch in from your TV's audio ouput to your receivers audio input.
Have you read the manual on your receiver and your tv? You can usually find most of your applications answered in there. Try it, you may learn some more added features of both your tv and receiver.
