Subwoofer cutting in/out
Username: Djmagnum4ce
I have a Onkyo TX-SR701 receiver and using a pair of MA silver series S1 bookshelves and a klipsh RW-8 powered sub. I have the setting all set to the same level as far as the white/pink noise is concerned ( 0db). speakers are set to "small" and the subwoofer setting is at 0 db. the problem I am having is when the volume is at a normal to high level, the Sub cuts out and the only audio is from the MA's. that lasts for about 10 - 20 secs and then the Sub cuts back in and sounds great for about 10 - 20 secs and cuts out again. I have the SUB wired via the LFE connection. and the Sub is has been set to both AUTO and ON on the back of the Sub with the same results. hope thats enough info to gather some ideas. thank you!
also, there is no distortion or popping sounds with the Sub or the MA's while this is going on. when the sub cuts back in it sounds great! and when its cut out, it just sounds like someone stole my bass!
Username: Devils_advocate
Post Number: 291
Does the sub have a speaker wire line in connection? Try using that; you'll at least find out if it is the sub or the receiver that way.
yes, it has left and right High level IN connection on the back. have never used those though
Post Number: 292
Try it; this way you can diagnose whether the problem is the subwoofer or the LFE out on your receiver.
