Hello everyone, I recently purchased a pair of Polk Speakers RTi12. I am using a Receiver HK 225 but it seems that the speakers might be a liitle too much for it. Can anyone please recommend a receiver that would best match these speakers ? Budget $1500.00 Max.
My choices would be NAD 673, Elite vsx55, Marantz7400, and H/K 630 or better yet a H/K 7200 if you can still find one. Another choice would be a Marantz 8300 which is discontinued, you might find one somewhere. By the way; does anyone know if Marantz is replacing the 8300 or eliminating the 8... price point?
Ed
Thank you very much Elite Fan, I really appreciate it. I will start my research based on your suggestions.
I do not see many comments or critics regarding Polk speakers. Are they any good compared to Paradigm or Def Tech?
I saw a photo on a website showing Marantz receivers at a recent show - there was an SR-8400 pictured.
Ed
After doing some homework, I have decided to go with the Elite vsx 55, just one question, I am currently using a 10" Infinity Entra Sub, would it be better to upgrade? Any recommendations? Thanks again !
Ed, Congratulations on the choice of the 55. Very good receiver and match with your Polks. If you have been happy with your sub in the past I don't see why you won't be happy with it in the future.
