joe sbrizzi Unregistered guest | How could u make a car amp into a house amp? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5526 Registered: May-04 | Sure, bring inside in a nice pot and give it plenty of light. I think they like to dry out between waterings. |
Bronze Member Username: PimpzeusUnited States Post Number: 21 Registered: May-05 | Joe listen to me man. Take your amp and bring it in. find something that puts off 12 volts of power DO NOT US A WALL TRANSDUCER. if it gets to hot u will get a surge off of the outlet that will fry your amp. i use a computer power supply. if u use that then use the yellow wire and the black one beside it. run a wire from your remote wire to your power. Or there is the old car battery in the house method. givea message back and tell me how it worked |
Bronze Member Username: Ww_daggerVancouver, WA USA Post Number: 17 Registered: Sep-05 | OK, do you want a real live, picture proven, working example of what to do? https://www.ecoustics.com/electronics/forum/car-audio/168117.html /GG |
