New member Username: Spoonerman
New York,
NY
United States
Post Number: 6 Registered: Jan-05
Posted on I bought a pair of totem arros as the result of advice from you'all. Thanks. Really love them. Now, i know many of you will cringe at this question. Why are there two sets of connections on the back of each speaker? I was reading something else and someone mentioned "bi-wiring." What's that? thanks in advance.... |
Post Number: 3862 Registered: Dec-03
Posted on bi-wiring is when you remove the jumpers and connect the speakers by using 2 separate sets of wires coming from one source. bi-amping is different, but can also be done. You use 2 separate amps to power the high frequency and low frequency transducers separately. |
