Anonymous | Are all speaker wire directional meaning that you need to hook up the wire with the writing on it toward the speaker? I have Acoustic Research 16 gauge wire and I never knew anything about this. If all my wire is not hooked up this way, does it matter? Any help is appreciated. Thanks... |
Silver Member Username: Devils_advocatePost Number: 287 Registered: Jul-05 | "If all my wire is not hooked up this way, does it matter?" No. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1391 Registered: Feb-04 | The only way an AC cable is directional is when it's shielded and only one side is grounded. Speaker wire is not shielded and the current flows half the time in each direction (AC), so this is no direction. AFAIK. |
Silver Member Username: Stu_pittNYC, NY Post Number: 473 Registered: May-05 | The only "direction" that makes any difference is that + or red goes to + or red, and - or black goes to - or black. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1392 Registered: Feb-04 | Opps. "so there is no direction" |
Silver Member Username: Stu_pittNYC, NY Post Number: 475 Registered: May-05 | I meant their is no 'direction' for speaker cables, not AC cables. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1393 Registered: Feb-04 | Stu, I was correcting my own error... nothing to do with your post at all. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5513 Registered: May-04 | Who's on first? |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1396 Registered: Feb-04 | No, Stu's on first. |
New member Username: RadoneSydney, NSW Australia Post Number: 5 Registered: Oct-05 | The whole unidirectional speaker wire is snake oil. I was talking to an electrical engineer who said he was a sceptic and couldn't believe he could hear the difference. I think he was just trying to defend his $200 purchase. Check out this speaker cable face-off. Very intriguing, http://www.audioholics.com/techtips/setup/interconnects/DIYSpeakerCablesp1.html |
