Speaker wire guage
Username: Garo
LondonUK
Post Number: 10
Could anyone shed any light on the confusing world of speaker wire guage.
I've recently bought some 2 x 2.5mm2 QED original wire to power a set of 6 olm speakers.
All sources of information regarding recommended maximum lengths specifies wire size in AWG.
Is there a method that i can find out what the AWG of my 2.5mm2 speaker cable is??
Thanks in advance
Username: Timn8ter
Seattle, WA USA
Post Number: 504
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_awg_to_metric
Username: Garo
LondonUK
Post Number: 11
Thanks for link, The link i've been given in regards to max recommended lengths
http://www.roger-russell.com/wire/wire.htm
states that the further distance you want to go, the THINNER the wire should be! Is this the case or am i confused!!
Further to that, currently i am running 13 AWG wire for 5m on a 6 olm load, would you suggest this is not appropriate
Username: Timn8ter
Seattle, WA USA
Post Number: 505
That doesn't sound right to me. The thicker the wire the less resistance. I didn't see that reference in the article you posted although I haven't taken time to read the whole thing. 13 AWG for a 5m run with 6 ohm speakers should be just fine.
Username: Garo
LondonUK
Post Number: 12
It doesn't explicitly state that fact, but what the "wire table" does show is that as the AWG gets smaller, (from 22AWG to 10AWG, the recommended maximum lengths go from 3 feet to 50 feet respectivley (at 2 olms for arguements sake.
I believe i'm right in saying that a 22awg is a thicker wire than a 10awg
Has this table got any credibility at all as it seems it defies the laws of physics??
Username: Jan_b_vigne
Dallas, TX
Post Number: 5488
You are incorrect, sir. 10AWG is a thicker cable than 22AWG. It is confusing, but that's how the system works. Before asking for a reason why this is so, you would be better off calling your local telephone service provider and asking why you pay "local service taxes" and where the money goes. By the time you get that answer, wire guage will be a piece of cake to understand.
Username: Stu_pitt
NYC, NY
Post Number: 470
I like that response Jan.
Gary - The lower the gauge, the thicker the cable. The higher the gauge, the thinner the cable.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1381
Wire size works in a log scale (like sound pressure in dB).
In sound, an increase of 3 dB requires a doubling of power. In wire, a decrease of 3 units doubles the area. So a single 12 AWG wire has as much cross-sectional area as 4 wire of size 18 AWG.
Dallas, TX
Post Number: 5493
As long as we are discussing American Wire Guage #'s. This is another case where most of the rest of the world seems to take more easily understood measurements.
