Username: Pugster STOKE ON TRENTENGLAND
Post Number: 1 Registered: Sep-05
Tuesday, September 06, 2005 - 12:35 GMT My Quad 99 stereo power amp keeps cracking and popping. This fault was diagnosed 12mths ago and sent to be serviced. It took 4 mths to get it back and now it's doing the same thing again. Quad said there was no fault found and charged me £60+. PLEASE PLEASE HELP ME AS I HAVE NO BACKUP AMP
Username: Jan_b_vigne Dallas,
TX
Post Number: 5478 Registered: May-04
Tuesday, September 06, 2005 - 13:49 GMT Contact Quad and tell them your situation. Possibly the problem will have become easier to trace at this point. Your description of the problem is too vague to give any more advice than that.
Post Number: 2 Registered: Sep-05
Tuesday, September 06, 2005 - 14:01 GMT The crackling is random and on both l and r simultaneously The volume is constant at low or high outputs ps Quad are useless the test they did took 1 month then 3 months of waiting until I contacted them to ask what was happening!!
TX
Post Number: 5481 Registered: May-04
Tuesday, September 06, 2005 - 14:55 GMT Well, Quad or one of the authorized service centers are the folks who will have to repair this; aren't they? There's no way to track this problem on a forum if Quad couldn't do it in a month.
Post Number: 3 Registered: Sep-05
Tuesday, September 06, 2005 - 15:09 GMT Thanks Jan, i'll try to find a local service centre as the amp is out of guarantee and it costs £30+ on del.
Username: Frank_abela Berkshire
UK
Post Number: 857 Registered: Sep-04
Wednesday, September 07, 2005 - 14:43 GMT Hmmm, sounds to me like the output capacitors are shot. Shouldn't happen to something that young. Frank.
Post Number: 4 Registered: Sep-05
Wednesday, September 07, 2005 - 14:58 GMT Thanks Frank, i'll get on to it.
TX
Post Number: 5518 Registered: May-04
Wednesday, September 07, 2005 - 15:50 GMT Output caps? Isn't the 99 a direct coupled design?
Saturday, October 01, 2005 - 02:11 GMT Hi David! Iv just started having the same problem as you. Do you get the poping even when you are playing music? My quad pops even when I switch it off. Im not too sure if its my CD, pre amp or power amp?
Post Number: 5 Registered: Sep-05
Tuesday, October 11, 2005 - 17:35 GMT Danny Mine pops and crackles constantly at the same volume, with or without an audio signal. I've isolated the power amp as the culprit.
