Powered subwoofer for sony dream system?
I'm wondering if I can use a powered sub on my Sony DAV-FX100W system. Thanks.
ed
Username: Project6
Post Number: 3725
yes
ed v.
Berny, thank you. Which powered sub would you recommend for about $200? You seem to know from all the other stuff i've read on here. Again, Thanks.
ed
ed v.
Thank you. Would you have a recommendation as to a powered-sub to use in the $2-300 range? Again, thanks.
ed v.
Username: Project6
Post Number: 3728
For your budget, the Velodyne DLS-3750 or the HSU STF-1. For the money I'll get the HSU, nicely received reputation for good tight bass.
You can hook it up by using the subwoofer output in the back of your Sony System and hooking it up to the high level input of the subwoofer.
Don't you like the subwoofer that came with your Sony?
Thanks for the compliment but I am only one of the many that contribute their opinion to this forum. :-) What we say are usually just that, you have to experience for yourself and decide what sounds good to you.
Now go out there and have fun with your HT!
cheers
ed v.
Again, thanks. I feel like I need more, so my dad suggested a powered sub...
