Help with mp3 to amp.. no head unit
alhitchcock
I tried using my mp3 player to connect to amp via y connector. there is no sound. Do i have to have a certain rca voltage to work the amp?
Username: Project6
Post Number: 3659
You need high level inputs on your amp. And if it is a stand alone car amp, you need a switch to turn it on. Is the amp turning on?
Either way you really should post this inquiry in the Car Audio section. This is the HOME AUDIO section.
