Silver Member Username: TpizzlePost Number: 303 Registered: Apr-05 | ive found a few lower-priced choices off a site edster gave me. which are the best, which should i stay away from? Polk Monitor PSW10 $180 JBL E150PBE $199 Velodyne DLS-3500R $250 Fluance DB-150 $200 KLipsch KSW 10" $300 Yamaha YST-SW305 $300 Dayton 10" or 12" $100 or $140 |
Silver Member Username: TpizzlePost Number: 304 Registered: Apr-05 | another choice is the HSU STF-1 for $300. thanks |
Silver Member Username: TpizzlePost Number: 306 Registered: Apr-05 | anyone have and suggestions? |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1708 Registered: Mar-05 | I'd stay away from all of those subs except for the Dayton and Hsu. Store-bought subs made by speaker companies in that price range are very poor quality for the money. |
Bronze Member Username: Rysa4Post Number: 23 Registered: Jul-05 | The Yamaha sub is just awful. Scratch that one. |
Bronze Member Username: PbdrPost Number: 52 Registered: Apr-05 | You might add the Wharfedale Powerecube 10" to the list. You can pick one up for $250 if you look on the web (free shipping and nice people from a place called big bang electronics). I got one recently and really like it, nice and tight. |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 803 Registered: Jun-05 | Yes Peter I have that sub very musical,good impact for movies,but as Edster says stay away from the rest of those subs except for the Dayton and Hsu. |
Silver Member Username: TpizzlePost Number: 307 Registered: Apr-05 | alright thanks. ive heard pretty good things about the Dayton, suprising its so cheap. the main thing is that whatever i get doesnt have distortion, i cant stand distortion. and i like a sub that can hit low frequencies. is the Dayton know for having these? also i assume you would recommend the 12"? the HSU STF-2 is a bit more expensive but would it be worth the extra $, ive heard good things about it also. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1716 Registered: Mar-05 | If you want tight clean bass especially for music, then yes I think the Hsu is worth the extra money. If you're mainly doing HT then the Dayton 12" should be fine. |
Gold Member Username: Paul_ohstbucksPost Number: 2157 Registered: Jan-05 | I'd suggest you buy nothing until you save enough money to buy a better sub. |
Silver Member Username: TpizzlePost Number: 310 Registered: Apr-05 | ya thats what im thinkin. but for the price is the Dayton a good deal. it sounds like it can hit lows and has some bass to it. is it known for not having much distortion? |
Gold Member Username: Paul_ohstbucksPost Number: 2160 Registered: Jan-05 | If you want to settle for a cheapo sub, then by all means, the decision is yours. You get what you pay for. I recommend saving a little longer...... I wouldnt consider anything in that market. If you can afford $300....surely you can save a little longer and get something better. Afterall....you'll always have it. Have patience........ |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1723 Registered: Mar-05 | db, post your question about the Daytons on avsforum.com and hometheaterforum.com Both of those forums have many more users who are Dayton owners. I've never heard any of them complain about distortion, just that the Dayton does HT well and music not as well. |
Bronze Member Username: MonolgouePost Number: 84 Registered: Feb-04 | The Dayton will be boomy |
allen robertson Unregistered guest | Outlaw audio has a new sub they are selling for $300. Their first sub, the LFM-2, was an absolute killer, check out reviews of that one with a Google search. I expect the new smaller one to be great also.http://www.outlawaudio.com/products/lfm2.html |
allen robertson Unregistered guest | Ooops. The LFM-1 was the first sub and the LFM-2 is the newest one. |
allen robertson Unregistered guest | It is actually probably easier to follow the links to reviews of the LFM-1 on the OUTLAW AUDIO site.http://www.outlawaudio.com/reviews/reviews_lfm1.html |
