New member Username: LawkPost Number: 9 Registered: Aug-05 | Thanks for your suggestions for my 2.1 setup. DA, my CS Model Six pair will be here tomorrow. Edster, my Dayton 12" sub will be here on Wednesday. Hopefully the 12" dayton wont be TOO powerful for my 12'x 15' office but, hey i can always turn it down. ![]() Thanks again. I'll post my review of the combo when I hear 'em. |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 771 Registered: Jun-05 | Lawk you should Quite a good time congrats,have fun! |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1671 Registered: Mar-05 | cool, I'll look for your review. |
Silver Member Username: Devils_advocatePost Number: 236 Registered: Jul-05 | Sweet. Have fun with your new toys Lawk. If you need any help or want setup suggestions feel free to ask. |
Anonnnn Unregistered guest | please don't forget to buy the ascends.....lol |
New member Username: LawkPost Number: 10 Registered: Aug-05 | I have no idea what the hell youre talking about. I am glad you can laugh about i though. |
Bronze Member Username: LawkPost Number: 11 Registered: Aug-05 | One question i have is this. The Manual for the Model six pair says to use 18GA wire. Should i go with that or something bigger? |
Silver Member Username: Devils_advocatePost Number: 241 Registered: Jul-05 | http://www.roger-russell.com/wire/wire.htm The wire length chart there will give you a good idea of how long a run you can use at what gauge. I prefer to go with the 2 ohm figures since you never really know how low the speaker impedance dips (regardless of the 8 ohm nominal bs figures). Personally I use 14 gauge although I noted no real difference when I switched from 16 gauge before. The 14 gauge looks nicer though! |
Anonnnn Unregistered guest | Bigger, get the 48 gauge you will be amazed! |
Gold Member Username: Project6Post Number: 3569 Registered: Dec-03 | Actually 48 gauge will be a LOT smaller. |
Anonnnn Unregistered guest | Really? you think? why thanks! you are awesome ! lol |
Silver Member Username: GavincummPost Number: 232 Registered: Feb-05 | how big is 1 gauge cable? Does it even exist? |
Anoni Unregistered guest | Ask Berny, he knows everything |
Silver Member Username: Devils_advocatePost Number: 266 Registered: Jul-05 | It does exist, and is 0.2893" in diameter. There is also a 0000 gauge which is 0.46" in diameter. |
