Bronze Member Username: Eieiei0101xPost Number: 54 Registered: Jul-05 | What bookshelf speakers should I try for my NAD L40? Budget available $300 US Consider high sensitivity and 8 ohms since it is only 20+20Watts and recomended for 8 ohms only Thanks a lot |
Gold Member Username: Project6Post Number: 3546 Registered: Dec-03 | This is a little bit more than your budget, but I think worth it http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html Or these ones http://www.axiomaudio.com/m3ti_main.html |
Anonnnn Unregistered guest | BOSE 301 |
Anonnnn Unregistered guest | Polk RTi6 |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1665 Registered: Mar-05 | I second the Ascend 170s suggestion but if you don't want to get a subwoofer I'd look at these: http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASB2%2E2&product_name =Audition%20B2%2E2%20Speakers%20-%20Black,%20Pair |
Silver Member Username: Devils_advocatePost Number: 230 Registered: Jul-05 | Klipsch B-3. |
Anonnnn Unregistered guest | Just get a pair of Bose 161's, best speakers in the world, just ask Paul, he is a real Audio Pro ![]() |
Anonnnn Unregistered guest | Ok enough....seriously, you might want to consider a pair of Monitor Audio's Bronze B2. http://www2.shopping.com/xGS-monitor_audio_bronze_b2~NS-1~linkin_id-3068595 |
Anonnnn Unregistered guest | btw, the Axioms and Ascends are only available through the internet, no way to audition them unless you order them, true that you have 30 days to return them if you are not satisfied, however, I am not sure that they would ship to Mexico. Besides both seem to be pretty over-rated but of course owners of these will strongly disagree they say: "These speakers are soo good they beat some that are three times the price!" omg...lol Ths spendors S3/5se are just incredible, they cost a litte over $1000.00 but I guess the ascends can compete with them...lol |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 765 Registered: Jun-05 | The Epos els 3 are right up your alley also,you might check out Onix at www.av123.com I dont know the model name or number but they are $149 apiece,and they have a real nice finish.They also have their own forum and they knowlegable,so check it out. |
Bronze Member Username: Eieiei0101xPost Number: 55 Registered: Jul-05 | NAD says i should use only 8 ohms, Would the Epos 4 ohms damage the amp if i use it only at low level? |
Anonnnn Unregistered guest | Yes |
Silver Member Username: Devils_advocatePost Number: 239 Registered: Jul-05 | Plenty of amps that say 8 ohms only are perfectly capable of running a 4 ohm load. In fact, NAD is particularly well known for being able to handle such loads. However, I would follow the manufacturer's advice in the matter before something bad does happen. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1682 Registered: Mar-05 | If it were any other NAD amp besides the L40 I'd say 4 ohms won't be a problem but a DVD/receiver compact combo like that would worry me...definitely ask NAD directly. |
