Sony Xplod Need Help!
Username: Wesleyfree
Brunswick, Georgia USA
alright,
i have 8 guage wire connecting the battery to the amp. 14 guage wire connecting my speakers to the amp. i have 2 kenwood 12's rated at 800 watts peak. the amp is a Sony Xplod 1800 watt Class D amp. i have size 30 fuses in the battery wire and the amp. my amp will no longer turn on because the lights showing overcurrent, offset, and thermal come on. the amp is a 4-channel MPA-6000. help.... please.
Username: Shortysblue
well first off is your power wire connected direct to the amp from your battery? second if so is there a fuse between thepower wire and the amp?
3.is there a distrubution block?
4. is the fuses in the amp good or bad?
5. is your speaks all hooked up right such as positive to negitave? even inside the box to the termanil?
6.is your amp settings to high such as the max power?
7. are the speakers brigged on the amp?
Halla
