New member Username: Santa199Post Number: 1 Registered: Aug-05 | could somebody here please tell me how i would connect two extra speakers to my Philips CW-F777 http://reviews.designtechnica.com/review661.html i have no idea how this would be done, but have two extra 10 inch spewakers and would like to hook them up could somebody please tell me where to go to find something to do this? |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1632 Registered: Mar-05 | Sure, go to Radio Shack and buy some speaker wire, some spades, a crimper, and one of these $12.99 marvels: http://www.radioshack.com/product.asp?MSCSProfile=745D84CBF04D14A48AA6FF9C89D722 C0BA68C1B04FE384678A5285FCD6E056B17AF21627FDABE316B90B3C038D68EBD6B7F9F3BD1712EA A9951ACB2590A05C6517EFE46941FEFDD1985D4EFD6321F5E70B4DE9B6C1D45512DCD9FB3DBCACB9 478EBE194968C21DD98995567EDCDD100AFC38253346404704280C7D8C7166A7DAB990BBF808DE1E 9B&cookie%5Ftest=1&catalog%5Fname=CTLG&product%5Fid=40-132 |
Gold Member Username: Thx_3417Post Number: 1071 Registered: May-05 | Good ole "Radio Shack" unfortunate we Brits don't have "Tandy" any more.... Instead we have "Maplin electronics." |
Gold Member Username: Paul_ohstbucksPost Number: 2106 Registered: Jan-05 | Does it have inputs for extra speakers?? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5318 Registered: May-04 | Speaker "outputs". |
Gold Member Username: Thx_3417Post Number: 1075 Registered: May-05 | Only the best well be allowed to use the best , and getting advice from someone that is an ecological time-bomb, well your guess is as good as mine........ Outputs is correct... |
New member Username: Santa199Post Number: 2 Registered: Aug-05 | thanks so much the only wother way i found how to do it cost like $200 and no, paul just for two speakers |
New member Username: Santa199Post Number: 3 Registered: Aug-05 | i looked at that thing and it says that it is limited to 10-watts per channel does that mean the speakers would only produce 10 watts when they're 300 watts as it is? and also, the extra speakers i found say 75 watt output does that mean thats all they'll do, or will the speakers blow when i turn them on? thanks for any help i can get these are probably dumb questions |
Silver Member Username: KanoPost Number: 602 Registered: Oct-04 | Speakers don't produce watts. That spec refers to the maximum watts the speakers can handle from the amplifier. |
New member Username: Santa199Post Number: 4 Registered: Aug-05 | ok thanks i know nothing about this stuff so will the speakers blow and will the sound quality go down? |
Gold Member Username: Paul_ohstbucksPost Number: 2140 Registered: Jan-05 | They wont blow unless you push your amp to the point where it's clipping the signal and distorting. |
New member Username: Santa199Post Number: 5 Registered: Aug-05 | thanks im off to radio shack ands ill leave the good people of this forum alone |
