Keeping it in the cube
Username: Floob
I work in a cloth covered cubicle and want speakers that will keep the music in my cube so as not to disturb my co-workers. Is there anything out there that will do this, i.e. create quiet but listenable sound that doesn't travel far, or sound that remains contained in a small space? I rea
Username: Joe_c
Atlanta, GA
Post Number: 1005
Headphones.
Username: Floob
An obvious solution, yes, but not very practical in the workplace when people are frequently coming up to you with questions.
Username: Jan_b_vigne
Dallas, TX
Post Number: 5295
There is no other. Sound will spread out from any speakers you use more than two inches from your ears.
Username: Project6
Post Number: 3513
It is difficult to prevent sound waves from travelling unless it is in a vacuum. Now if you can find a way to isolate the sound in one specific area...make sure that you get a patent.
Username: Timn8ter
Seattle, WA USA
Post Number: 473
Bryan,
Are you interested in DIY at all? I have a very easy to build and inexpensive design for desktop speakers that you can power with a $40 amp. Perfect for the office environment and still delivers quality sound.
Username: Project6
Post Number: 3517
Hi Tim,
Does your company have an outlet in the Philippines?
I am interested in these desktop speakers.
Username: Timn8ter
Seattle, WA USA
Post Number: 474
Yes, we do.
http://www.pi.alegriaaudio.com
The speakers I'm talking about here use the Aurasound NS3 drivers.
Reilly
Which one do you think has a better deal Dishnetwork Deals or Directtv Deals?
