Help with Onkyo TX-SR500
Username: Rcscobey
I have had this receiver for 5 years and it has worked great. But yesterday, I got greedy. I was trying to use the Svideo jack on the front to connect my computer to the TV. I could not get it working and then tripped over the S video wire and pulled it from the front (the receiver did not move more than two inches though - it certainly did not come off its shelf if experience physical harm). Anyway, sometime during that process (with the computer or wire), the receiver died. Now, all it shows is the standby light. When you hit the power button (on the remote or on the receiver), the standby light does off, but the display, audio does not come on. I have tried unplugging it, using a different outlet, unplugging all of the speaker wires and components with no luck. It is like it needs to be "reset" - like there is an internal power button or something.
Any help would be great. The only service center I can find is at 7 week turnaround.
