New member Username: TmansdcPost Number: 4 Registered: Nov-04 | I want a good cd r/rw compatible boombox with qsound capability. (I have old sega cd games that support qsound that sound much better with qsound then regular stereo.) So what should I do? Can someone recommend a new boombox that has qsound capability? Must be $100 or cheaper. Thanks. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1604 Registered: Mar-05 | does it have to be a boombox or can it be a compact minisystem? |
New member Username: TmansdcPost Number: 7 Registered: Nov-04 | Sure, it can be a compact minisystem. Must cost under $100 though. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1651 Registered: Mar-05 | This Sharp wasn't bad for the money and I think it has an alarm feature so it can be used like a clock radio. http://samsclub.com/eclub/main_shopping.jsp?coe=0&oidPath=0%3a-23542%3a-23589%3a -44061%3a-44082%3a920466&mt=a&n=0&BV_SessionID=_SC_1956849389.1124953283_CS_&BV_ EngineID=ccchaddfhlghmdmcfkfcfkjdgoodflg.0 PS. I'm not a gamer so I have no idea what in the hell "qsound" is. |
Bronze Member Username: TmansdcPost Number: 11 Registered: Nov-04 | It says that has expired. Could you post another link? And I hear Qsound is sometimes used for music cd's as well. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1685 Registered: Mar-05 | go to their website and search for the model or item number. ======= Model: XLMP60 Let this 120W compact shelf system boost your energy level to the maximum. With its 5 CD changer and 45W subwoofer, music has never sounded so good. System is also CD-R/RW and MP3 playable. All these great features in one incredible unit. Item: 464922 Sharp 120W Micro Shelf System $89.84 Features # 120 Watt Micro Component System with 5 CD Changer and Subwoofer # CD-R/RW and MP3 Playable # 32 Track Programmable Music Selector for CD with random and repeat playback # 6 mode Electronic Equalizer # Clock Timer/Sleep Functions # Remote Control Product Specifications # Power Output: Speakers: FTC: 37.5 W per channel + 45W Subwoofer # Terminals: Headphone, FM/AM Antenna, Front Speakers, Subwoofer, Video AUX input |
