NAD 3200 volume knob and hissing sounds
Username: Sudhir_k
I brought a NAD 3200BEE couple of months back..Recently I have started observing a hissing sound (some thing like static on the phone)in the right speaker when I turn the volume knob. Its more prominent when I use the remote..I called up the dealer and he said it needed some cleaning. Any one's got any idea's on this....Except for the hiss the amp sounds great...
Username: Jan_b_vigne
Dallas, TX
Post Number: 5136
"Any one's got any idea's on this"
Yes, save your repair tickets for any work done on the amplifier. If the VC shows problems already, it could mean a defective part that will need replacing instead of constant cleaning. Receipts from all service performed will bolster your case if the time comes to insist the issue be resolved to your satisfaction.
Username: Sudhir_k
Thanks Jan,
I was thinking the same...
sudhir
Username: Sudhir_k
Dealer replaced the AMP with a new one free of cost...not even shipping...
Just a little note, this is usually a result of dust on the contacts, and does need cleaning. Do not open unit to clean yourself as this could void your warranty.
www.digitalhsolutions.com
